Unable to complete install fusion team
When installing fusion 360 on an education license I am prompted to create a fusion team however after following the prompts and pressing finish i get an error message " Unable to create team, Either there is a network issue or you do not have the permissions needed for this. Please try again or contact your administrator."
Rushikesh.kadam
@Anonymous can you once try the steps mentioned at https://knowledge.autodesk.com/support/fusion-360/learn-explore/caas/sfdcarticles/sfdcarticles/Unabl... and https://knowledge.autodesk.com/support/fusion-360/learn-explore/caas/sfdcarticles/sfdcarticles/Join-... , the error you observed is different but the solution may work.
Rushikesh Kadam.
If my reply was helpful, please click the "Accept as Solution" or the “Like” button. This helps others to find the answer more quickly!
Rushikesh Kadam
Senior QA Engineer
Quality Assurance
