Unable to change parameters
gmdimarzio88
Message 1 of 24
gmdimarzio88
When I try to change parameters the software hangs up and doesn't open the command. I used the command earlier today. Any thoughts?
Replies (23)
Message 21 of 24
davetpilot
Community Visitor
Community Visitor
I have tried all of these solutions multiple times. Nothing works. Fusion 360 is just broken...period. It really sucks because it is such a valuable tool.
Message 22 of 24
walkernb2020
Hi Jeff
Last month, I could open this model and see parameters such as length, width, height of the box, so I could edit them. Now when I open it, the same model!, there are no parameters to see?? I'm still accessing "Change Parameters" and seeing the dialog - but there's nothing there. Is there something else I need to do to enable them now? thanks
I'll upload the model, and the screenshot of my dialog.
Hope you can help.
Barney
Message 23 of 24
davebYYPCU
Download model is different to the picture.  Model works as expected,
but with a linked component as per picture, (needs Edit in Place) it would have the error you are talking about.
Might help....
Message 24 of 24
walkernb2020
Aha! I looked and found out how to do that. Thank you - now I can enter parameters.
I appreciate you answering so quickly and helpfully - cheers, Barney @onekickduck
