Unable to change name of project in Data Panel
vlhennon
vlhennon
I was able to make a copy of a Design within the Data Panel. Then I tried to change the name of that copy with Rename. The original name remains.
Fusion 360 Personal version.
Yes, got out of 360 and back in.
jhackney1972
When using the Rename command in the Data Panel on anything, the key to it working is after you type in the new name press Enter on the keyboard before doing anything else.  If you click on the screen to accept the changes you have made will disappear.
John Hackney, Retired
