If you share the file, we can analyse the conflict described.
File > export > save as f3d on local drive > attach it to the next post
günther
This isn't a problem with the joint conflict, I believe one exists. The problem is the spurious HTML tag embedded in the message. I think you could find that in the code.
Embedding in the post is a known problem.
Instead, attach the link to the next post or create an mp4 file and paste it.
günther
Thanks, I didn't know about that. I guess I don't run into enough bugs! The screen shot is attached.
Thanks for letting us know the typo issue. I have created an internal defect(FUS-119909) to ask our development team to fix it.
Steven
https://www.autodesk.com/campaigns/fusion-360/insider-program
Oops, logged a ticket in error. Steven beat me to it.
I think your design might be required to reproduce the issue for debugging. None of the testers can get that warning (with the typo) to appear.
Sorry to say I'm a newbie at this and eventually gave up, so I'm not sure what I did. I've tried to reproduce it just now and could not get the same error message; the error I get now is just one line.
In case it helps, I'm attaching a screen shot of my design. The brown components are ground. The green circles show where two working sliding joints are in place. The red circle shows where I was trying to put in a joint and kept getting the error message that I reported. The non-brown components were linked from another design.
If this doesn't help, then we should close this out.
Jim
Thanks. We'll keep looking. The html should show up in a plain text string and be found by searching the code.
Take care,
