Two distance chamfer issue
hello, when i select 2 edges chamfer working strange, it not changes direction for different edges. look at screencast please
https://autode.sk/2xgnxEf
long time ago issue... is there some moving on fixing it? i understand that there plenty ways to obtaine result that i need and i already get chamfer that i need, but i think that a year old bug should be repaired)))
https://forums.autodesk.com/t5/fusion-360-support/chamfer-bug/m-p/7261765
jeff_strater
A fix to this bug is being investigated now.  Can't promise a date when it will be fixed, but it is high priority right now.
Jeff Strater
Engineering Director
HenryDara
Has there been any progress on this problem? Not sure if its related, but I am now having a similar issue with this type of chamfer, where the drag arrows always flip face long for short. I can get them to finally work, but if I have to edit, I cant because they were somehow created in conflict with eachother. Also when I try to edit a chamfer that I finally get correct with my little workaround, the chamfer faces flip long for short, and fusion will not accept any edit to the feature. I can cancel, but can really never edit that chamfer again. I will have to delete it and replace it, which of course causes alot of downstream errors, and so forth. It would really add to our productivity if these things could be fixed, as they really do cause a lot of extra work for us.
Thank you.
HenryDara
Here a screenshots of the feature as originally created, and then when trying to edit it.
