TURNING PROFILE Error: Internal CAM kernel error
smcdonald_76
smcdonald_76
Both Turning profile Roughing & Finishing throw an error
"Error: Internal CAM kernel error. Please report through your support channel."
I tried I.D> & O.D.
I tried different tools.
I even opened a previously working program and tried to create a new profile.
Seems this command is juts plain broken.
earlier newly created folders were giving me read errors for an hour then magically just started working again.
Anyone else having this problem today?
Maybe it will work tomorrow?
seth.madore
Can you share a Fusion file that is doing this?
Is this all happening on the same computer?
Are you using Windows 7 or 10?
Seth Madore
smcdonald_76
I found the problem was using windows 7.
I replaced the camkernel.dll file as described in the "Manufacturing Workspace Issues in Windows 7" article here and that fixed it
THANKS for the quick reply!
patl1
I am having this problem on a model in a profile turning roughing toolpath. The same file posted just fine a month ago. I screwed around with it and made it work by changing the remaining material from .004" to .002". this of course is not what I want for remaining material and makes no logical sense that it corrected the error on a toolpath that used to run fine. I am using window 11.
