Trouble in designing and 3d print a fixed-wing drone wing
- Mute
- Permalink
- Report
Hello everyone, I'm facing some trouble with my fixed wing drone internal wing rib structure
So, I have followed the steps of this video https://youtu.be/QJjhMan6T_E?si=0Bmh6c-Hv2hbTvNv
My attempt to make the structure in this video ended up with the following result
as you can see it looks fine but after combining with cut the internal ribs with the wing some ribs pentrate the wing body creating gaps like this
When trying to print it using something like vase mode in the creality slicer called `spiralize outer contour` these gaps is created which makes the print goes completely destroyed and some edges snaps if I try to apply little pressure on them so what do you think the problem is and how to solve it BTW here is the sketch of the ribs pattern
the f3d file is attached
