Trouble in designing and 3d print a fixed-wing drone wing
m_alzurghni123
Message 1 of 10
m_alzurghni123
Hello everyone, I'm facing some trouble with my fixed wing drone internal wing rib structure
So, I have followed the steps of this  video https://youtu.be/QJjhMan6T_E?si=0Bmh6c-Hv2hbTvNv
My attempt to make the structure in this video ended up with the following result
 as you can see it looks fine but after combining with cut the internal ribs with the wing some ribs pentrate the wing body creating gaps like this
When trying to print it using something like vase mode in the creality slicer called `spiralize outer contour` these gaps is created which makes the print goes completely destroyed and some edges snaps if I try to apply little pressure on them so what do you think the problem is and how to solve it BTW here is the sketch of the ribs pattern
the f3d file is attached
Replies (9)
Message 2 of 10
TheCADWhisperer
@m_alzurghni123
Message 3 of 10
m_alzurghni123
here is .f3d file attached
Message 4 of 10
m_alzurghni123
Any help?
Message 5 of 10
TrippyLighting
You did not attach anything to your post!
Message 6 of 10
m_alzurghni123
@wersy
Message 7 of 10
wersy
If it is not stable enough, you have under-extrusion or poor layer adhesion.
To increase layer adhesion increase temperature.
May also depend on the material.
BTW, you have to design the elevons first.
Message 8 of 10
m_alzurghni123
So it supposed to have gaps?
Message 9 of 10
wersy
No, there must be no gaps.
The walls of the gaps must melt together.
Seams remain visible.
Message 10 of 10
m_alzurghni123
There must be no gaps in the design itself or after printing it?
