Transparent objects and Offset
- Mute
- Permalink
- Report
For some time now, I have encountered transparent objects that are in the same shapes as previously created bodies, but are not sketches of those bodies, and are also not planes used to create said bodies as turning off the bodies, planes or sketches (or all three) will not remove them. The problem is that, like any item in Fusion 360, you cannot get past them to work on surfaces beneath them. I sometimes have managed to delete them using the Delete tool, but they always reappear, usually before I can perform the task I had removed them to do.
My second question is this: is it only possible to Offset a surface or body once? Sometimes I want to trim a both sides of a body that I have extruded though another body using the technique recently explained by Lars Christensen on one of his videos, But once I have Offset and Split the body in question, it will not permit me to repeat the procedure to trim the other side.
