Toggle on Joints visibility on an assembly when "saving as mesh" on of the external components
dariusz.wedrychowicz
Message 1 of 11
I'm working on a fairly complex assembly file, which has mostly external components, which also in many cases are assemblies of external components. I have joints visibility turned off for transparency (under Display Settings). However when I right-click on any component and choose "Save as mesh" the joints visilility changes to on. Not very annoying, as I don't do if often, however looks like an issue with the software.
Replies (10)
Message 2 of 11
dsouzasujay
Hi @dariusz.wedrychowicz ,
Upon attempting to reproduce the defect, I was unable to do so. I've attached a video showing my findings, and I did not encounter any issues on my machine.
If you are still able to reproduce the defect, please export your *.f3z file to your local drive and attach it in a reply here, it would greatly assist us in further investigating the issue.
(view in My Videos)
If my answer helped, please 'Accept Solution'
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
Message 3 of 11
Thanks for the message. I noticed that you "saved as mesh" the assembly I was working with compontens inside the assembly. Please see the attached video. And please don't mind the contnent of the assembly this is only a small piece of what I'm working with. I cannot share more, apologies.  However this does not change the behaviour.
Message 4 of 11
Sorry have issues when trying to attach the *.f3z file. Not exactly sure why, size is only 6MB.
Message 5 of 11
(view in My Videos)
Message 6 of 11
dsouzasujay
Could you follow below steps and share the link.
Sujay
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
Message 7 of 11
Hi @dsouzasujay,
Please find the link below.
https://a360.co/3H1cXbo
Message 8 of 11
tyler_henderson
We've introduced a Preference to set the default visibility state of Joint icons in the canvas for new designs.  Please check this Preference setting.  If it is set to "Visible" then new designs will have the Object Visibility for Joints turned On for new designs.  And since "Save as mesh" creates a new design, it will obey this setting.  Change the Preference to "Hidden" to have the Object Visibility for Joints turned Off for all new designs.
Tyler Henderson
Principal User Experience Designer
Message 9 of 11
dsouzasujay
Thank you for reporting this issue! It has been logged as FUS-212098 in our internal tracking system.
Please follow Tyler's recommended workaround to prevent the joints from being displayed.
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
Message 10 of 11
Closed-Loop-Bot
We're happy to report this issue has been resolved. Update Fusion to the most recent version to apply the fix. If this update resolved your issue, feel free to click the "Accept Solution" button to help other community members find the answer more easily. If the issue persists after updating, don't hesitate to reach out to us by replying to this thread. We're here to help! Let us know if you need any further assistance!
Message 11 of 11
dsouzasujay
@Closed-Loop-Bot
Issue is still not fixed FUS-212098, We have suggested a workaround.
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
