Part of the sketch is disappearing when adding a line
jonasgeiser
Observer Observer
jonasgeiser
Observer
Observer
New to Fusion 360 and trying to make a LED Sign. But when editing the sketch, adding a new line, some parts of the sketch is disappearing. What am I doing wrong here?
Thanks.
jeff_strater
I don't think you are doing anything wrong.  I suspect that some curves get solved unexpectedly when you create the new line.  Can you share the design here?
Jeff Strater
Engineering Director
jonasgeiser
Observer
Observer
Hi, thanks for the quick response, for example it happens when connecting the bottom under the "X"
thanks
jonas
jeff_strater
Thanks for sharing the design, @jonasgeiser - I did not realize at first that the geometry was generated from a sketch offset.  It seems that there is a bad bug with offset on this design.  As you've seen, closing that triangle under the X causes bad things to happen.  Also, if I change the offset distance at all, even worse things happen.  I will create a bug for this.  In the meantime, if you delete the offset, it does seem to get rid of the problem (at the cost of a bunch of dimensions being added to the sketch).  Not sure if that is OK with you, but I thought I'd offer it:
Edit:  The Fusion bug is:  FUS-224303  Thanks for reporting it.
Jeff Strater
jonasgeiser
Observer
Observer
Hi Jeff,
that works for me, thanks for the quick help, really appreciate it.
Have a nice day 🙂
Jonas
