Threads
Threads
tebawg
Message 1 of 13
Threads
tebawg
I tried an xml file from this posting, which is a cool set-up (https://forums.autodesk.com/t5/fusion-360-design-validate/how-can-i-make-an-internal-rms-royal-micro....
But the angle is 60 degrees, and these are Whitworth threads, so they have to be 55 degrees.  Is there a way to specify that in the xml file?
Thanks.
Replies (12)
Message 2 of 13
HughesTooling
There's an article here with some info but I seem to remember it's broken at the moment so might not work.
https://knowledge.autodesk.com/support/fusion-360/learn-explore/caas/sfdcarticles/sfdcarticles/Custo...
Mark
Mark Hughes
Owner, Hughes Tooling
Message 3 of 13
HughesTooling
Looking back at some of my old posts and it does look like the whitworth form custom threads are broken. Post #4 in this thread has a file that used to work but doesn't anymore, not filleting the form. And a post I made a year ago here that never got any reply!
Mark
Mark Hughes
Message 4 of 13
tebawg
Yes, that article link is given in the linked article referenced in the original post.  But it looks like the forum mangled the link.  So I'll try again: (https://forums.autodesk.com/t5/fusion-360-design-validate/how-can-i-make-an-internal-rms-royal-micro...)
So parsing the xml file, the original had a ThreadType with angle 60 for all the types.  Breaking out RMS into its own file and setting the angle to 55 made it work.  Trying two ThreadType sections in the same xml actually makes the hole tool suddenly not do anything.  Didn't see any error messages.  But breaking it into two xml's worked.
Thanks.
Message 5 of 13
HughesTooling
Are you getting the correct Whitworth form with filleted major\minor diameters?
Mark
Mark Hughes
Message 6 of 13
HughesTooling
Thanks.
Yes you should only have one set of thread info at the top of the XML file. Something like this for BA threads.
PS please don't attach picture, you can just paste them inline from the clipboard.
Mark Hughes
Message 7 of 13
tebawg
"PS please don't attach picture, you can just paste them inline from the clipboard."
I did the drag drop of a file like the web page said to do.
Message 8 of 13
HughesTooling
Do you mean here for drag and drop?
You don't want pictures as attachments as it makes it hard to read the message and view the picture. There's also an option to insert pictures in the editor as well.
Thanks Mark
Mark Hughes
Message 9 of 13
CGBenner
@tebawg @HughesTooling
Hey guys, has this thread issue been resolved?  Do we need to tag in someone on the Fusion team to take a look?
Chris Benner
Message 10 of 13
HughesTooling
@CGBenner  This is still a problem. I tagged @Phil.E in on another thread on this THREAD here but not sure if it's been logged.
Also looks like I made a post a while ago about this problem and it shows how the inbuilt threads are correct but if you copy the inbuilt XML file and rename, the form of the thread is incorrect.
Thanks Mark
Mark Hughes
Message 11 of 13
Phil.E
@HughesTooling I logged this as FUS-88310 but to be honest I don't understand the problem.
Is the problem that Fusion doesn't provide these threads by default? Or that you cannot hack the xml to produce the correct result? What would be the best root-cause solution here?
Phil Eichmiller
Software Engineer
Quality Assurance
Message 12 of 13
HughesTooling
@Phil.E  I replied in the other thread but the problem is, one Fusion doesn't come with these threads built in and two the custom XML files no longer produce the correct Whitworth thread form with fillets.
Mark
Mark Hughes
Message 13 of 13
Phil.E
Thanks Mark. I've added that to the ticket. The solution from a development perspective would be to include this thread form in Fusion. Sounds like that should be possible, but I have no idea why it's not already there.
Phil Eichmiller
Software Engineer
Quality Assurance
