Custom thread with Whitworth form BUG.
Seems like custom thread files with a Whitworth form, modelled threads no longer work. There's an example file in this old post that shows it working. If you try now you just get a trapezoidal thread, the default if you don't specify the form. The form is specified in the XML file as type 7, Whitworth form.
This is what I get now. I've tried a couple of old XML custom files that worked in the past but they all fail now.
Just as a test to make sure there are no errors I copied the built in BSP thread XML file, added the thread form as 7 and this also fails. Not sure why the built in BSP XML doesn't have the thread form type set, seems like something that's hard coded into Fusion.
Here you can see the correct form using the built in BSP thread on the right.
Mark
Mark Hughes
Owner, Hughes Tooling
