Thread Tool bug of alignment when created thread
WMLogistic
Message 1 of 27
WMLogistic
Hello
Before, it didn't matter how you built a screw / nut assembly, on an offset plane, on an angular axis, whatever ... the alignment was always perfect ... Now this is no longer the case! ..
Voici une petite vidéo de la conception ... pas difficile à reproduire ...
Merci.
Cordialement / Best Regard
Manuel Warland
Replies (26)
Message 2 of 27
WMLogistic
Here is another example with a box... This never used to happen before.
Voici un autre exemple avec une boite ... Avant cela n'arrivait jamais.
Moderator note: English translation added
Manuel Warland
Message 3 of 27
g-andresen
after several tests I can not confirm the behaviour
günther
Message 4 of 27
HughesTooling
Not 100% sure about what your complaint is but the crescent shape is because when you add a M10 thread to a hole the major diameter is increased to 10.19mm, the crescent is just the helix running out of the face.
This is a 4 view of a sectioned nut with a 10mm cylinder through it.
Mark Hughes
Owner, Hughes Tooling
Message 5 of 27
HughesTooling
If your complaint is about the 2 threads not aligning, Fusion has always worked that way and depends on the end face alignment and the pitch.
You just need to rotate one part to get the 2 helixes to align. Here's a old thread about the same problem and there are several other if you search.
Mark
Mark Hughes
Message 6 of 27
WMLogistic
[FR]
Je me demande si dans les autres logiciels qui sont payant ... ah ben tiens ... comme Fusion 360 qui n'est plus gratuit ou fortement bridé ! ... si on doit s'ammuser à faire tourner une des deux parties pour aligner deux filetages entre-eux lorsqu'ils sont fait en même temps ?!
Ne me dite pas que vous n'avez pas été capable de corriger cela depuis tout ce temps quand même ? si ?
Allez un effort les développeurs !
If Second thread is on same axis of first thread then
      Take same point of réference for second thread
End If
C'est pour rire, mais ne me dite pas que cela ne dérange personne quand même ... on joue dans la cour des grands là, Fusion n'est plus au stade du développement maintenant.
[En]
I wonder if in the other paid software ... oh well ... like Fusion 360 which is no longer free or strongly restricted! ... if we have to amuse ourselves by rotating one of the two parts to align two threads between them when they are done at the same time ?!
Don't tell me you haven't been able to fix this in this same quad time this whole time? if ?
Go an effort the developers !
      Take same point of reference for second thread
End If
It's a joke, but don't tell me that it doesn't bother anyone anyway ... we're playing in the big leagues there, Fusion is no longer in the development stage now.
A fix would be welcome.
Manuel Warland
Message 7 of 27
WMLogistic
[FR]
Imaginons que je veuille imprimer un truc fileté male femelle dans la même position, donc ensemble et non séparément ... si je suis un débutant, si je ne fais pas attention en vérifiant par un section analysis et que je ne fais pas tourner un des deux body pour aligner les deux filetages qui devraient l'être ! ... à la fin de mon impression je me retrouve avec deux pièces complètement soudées ensembles et j'aurai perdu du fil et du temps pour rien ... cqfd
[EN]
Suppose I want to print a male female threaded thing in the same position, so together and not separately ... if I am a beginner, if I am not careful checking through an analysis section and I am not rotating one of the two bodies to align the two threads that should be! ... at the end of my printing I find myself with two pieces completely welded together and I will have lost thread and time for nothing ... cqfd
Manuel Warland
Message 8 of 27
WMLogistic
[FR]
Encore un autre exemple, imaginons je veux faire un objet en U et faire en sorte qu'une tige filetée le traverse ...
J'effectue 3 thread (et même en faisant les deux filetages femelles d'un coup ça fait exactement la même chose), je m'aligne en faisant une rotation d'un côté et je suis suis pas bon de l'autre côté ... Ce n'est pas normal !
Là mon objet est inutilisable car je ne peux pas viser ma tige filetée de l'autre côté ...
[En]
Yet another example, let's imagine I want to make a U-shaped object and have a threaded rod go through it ...
I do 3 threads (and even doing the two female threads at once it does exactly the same), I line up by rotating on one side and I'm not good on the other side ... This is not normal!
There my object is unusable because I cannot aim my threaded rod on the other side ...
Manuel Warland
Message 9 of 27
g-andresen
Please show a real life example of such a design and demonstrate the movement.
günther
Message 10 of 27
WMLogistic
ok ... voilà un exemple de la vrai vie d'une telle conception.
Ca ira ou il faut d'autre exemples encore ? Parce que bon, si je demande un truc ce n'est pas par caprice ... de telles conception existent et il y en a des tonnes d'autres dans le même style.
Alors faites un effort pour aligner ces foutus filetages svp, merci.  Et ne me dit pas de concevoir ma pièce autrement et d'avoir a rajouter tonnes d'opération en plus pour y arriver car dans la vraie vie, on usine la pièce, on lui donne la forme qu'elle doit avoir et ensuite on fore les trous et on y fait les filetages ... On ne commence pas d'abord par les trous et les filetages avant de donner la forme finale à la pièce.  On est d'accord ?
Manuel Warland
Message 11 of 27
TheCADWhisperer
2 threads, one male and one female.
Do the female thread as on feature - same as in the real world manufacturing process.
Attach your file here if you can’t figure it out.
Message 12 of 27
TheCADWhisperer
That is how you progress from beginner to professional - you check and verify everything.
Message 13 of 27
g-andresen
1. threads as shown in#8 would block each other.
2. your choice of words is simply inappropriate.
günther
Message 14 of 27
WMLogistic
günther
C'est sur que vu la façon dont fusion 360 façonne les filetage, ça ne peut QUE se bloquer ... CQFD !
désolé mais je ne parle pas le langage technique ni l'anglais, donc je fais comme je peux pour me faire comprendre.
Vous pouvez clôturer le sujet, j'abandonne vu que vous ne voulez rien comprendre, ni rien entendre et que vous prenez la grosse tête.
Manuel Warland
Message 15 of 27
g-andresen
I am talking about a real process on real objects not a construction in Fusion.
günther
Message 16 of 27
patrick.emin
@WMLogistic
It is sometimes difficult to explain technical issues and we understand that.
But please note that this forum, as I told you is in English, that I offered you to translate your messages into English if you felt the need.
Please also respect the rules and avoid using inappropriate language.
The community is ready to help you under these conditions which are the ones you have accepted by using our forums.
Thank you.
French translation for you:
Bonjour,
Il est parfois difficile d'expliquer les questions techniques et nous le comprenons.
Mais veuillez noter que ce forum, comme je vous l'avais indiqué est en anglais, que je vous avais proposé de traduire vos messages en anglais si vous en ressentiez le besoin.
Veuillez également respecter les règles et éviter d'utiliser un langage inapproprié.
La communauté est prête à vous aider à ces conditions qui sont celles que vous avez acceptées en utilisant nos forums.
Merci.
Patrick Emin animateur de la communauté francophone
Vous avez trouvé un message utile? Alors donnez un "J'aime" à ce message!
Votre question a eu une réponse satisfaisante? Voulez vous avoir l'amabilité de cliquer sur le bouton
 APPROUVER LA SOLUTION  en bas de la réponse qui apporte une solution?
Signez notre Livre d'Or
Message 17 of 27
WMLogistic
günther
Je t'ai mis des photos d'objets réels qui ont 2 filetages de part et d'autre afin d'y accueillir une tige filetée tout en travers ... ces objets qui se mettent sur une poutre d'acier servent à maintenir des aérations ou des passe câbles ... plus réel que ça, je peux pas te le démontrer ... Ce processus se fait dans la vraie vie, donc il serait bien que ce soit possible aussi dans fusion 360.
Bye
Manuel Warland
Message 18 of 27
TheCADWhisperer
Bien sûr, c’est possible dans Fusion 360. Je l’ai fait des milliers de fois dans le monde réel dans l’atelier et je suis tout à fait certain que je peux le faire dans Fusion 360. Joignez votre dossier ici pour une démonstration de la bonne technique (qui est essentiellement la même que celle effectuée dans l’atelier).
Of course it is possible in Fusion 360. I have done this thousands of times in the real world out on the shop floor and am quite certain that I can do it in Fusion 360. Attach your file here for demonstration on the correct technique (which is essentially the same as done on the shop floor).
Message 19 of 27
WMLogistic
@TheCADWhisperer  a écrit :
... je suis tout à fait certain que je peux le faire dans Fusion 360 ...
... and am quite certain that I can do it in Fusion 360 ...
ok vas-y ... montre-moi, fais une vidéo pour me montrer comment tu fais et on verra 😉
ok go ahead ... show me, make a video to show me how you do it and we'll see 😉
Manuel Warland
Message 20 of 27
TheCADWhisperer
You forgot to Attach your *.f3d file here so that I can create video of the technique used in the real world.
I have to get another project done at the moment - I'll check back in a while to see if you have Attached your *.f3d file.
