There was an error while logging in to Fusion 360 (mac)
scottian.hollins
Message 1 of 9
scottian.hollins
Fusion 360 (mac) will not Load. report error "There was an error while logging in to Fusion 360 (mac)"
System & OS
MacBook pro (13 inch, 2017, Four Thunderbolt 3 ports)
3.1GHz Corei5
8GB 2133MHz LPDDR3
Intel Iris Plus Graphics 650 1536 MB
macOS Mojave version 10.14.4
I've completed the following...
1. Followed support articles. -
   1a -Network restarted - Done
   1b Firewall disabled - Done
   1c check time zone and current time is correct on system - Done
   1d macbook pro restart
   1e delete LoginState.xml file - Done
   1f Cleanly Uninstall using Fusion Cleaning tool - Done
   1g install latest update for Mac OS (10.14.4) - Done
   1h download latest .dmg of Fusion 360- Done
   1i reinstall Fusion 360 - Done
Results...
Same error message... "There was an error while logging in to Fusion 360"
Relaunched Fusion 360 using a different network connection
2. Logged into Autodesk account online to check my username & password - all fine, I can access my designs online.
3. Downloaded log files and attached them to this post.Screenshot 2019-05-11 at 14.17.22.png
Please can anyone help with this error. I've followed similar errors posted online but nothing has solved the issue for me.
Scott
Replies (8)
Message 2 of 9
scottian.hollins
Okay... I'm answering and solving my own issue with Fusion 360.
This may help some else with the same problem.
https://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/How...
extract below that worked for me.
Solution:
Add some exceptions for the domains utilized by Fusion 360 in the Bypass Proxy Settings:
1.    Choose > Apple menu > System Preferences, then click Network
2.    Choose the network service you use from the list, for example, Ethernet or Wi-Fi.
3.    Click Advanced, then click Proxies
4.    Copy and paste the domains below in the Bypass proxy settings for these Hosts & Domains field.
*.autodesk.com, *.autodesk360.com, *.google-analytics.com, *.akamaiedge.net, *.ui-dls360.autodesk.com, *.services.autodesk.com, *.fusionapi.autodesk.com, *.a360-statusdashboard.s3.amazonaws.com, *.accounts.autodesk.com, *.api.autodesk.com, *.appstreaming.autodesk.com, *.amazonaws.com, *.notifications.api.autodesk.com, *.mcmaster.com,
*.uploads.protolabs.com, *.deploy.akamaitechnologies.com, *.tracepartsonline.net, *.akamai.com
5.    Select OK and Apply
Message 3 of 9
I also have the same problem and I did try your solution. It COMPLETELY WORKED!!! Thank you :") You saved my day 😍
Message 4 of 9
Still getting the same logging in error..!! please help me wasted almost a day..!
Message 5 of 9
mdahlFK4L7
Thank you!
Thank you!!
Thank you!!!
Message 6 of 9
I have the same problems. exceptions dont helps. what can I do?
Message 7 of 9
steve.gelezi
i have the very same problem and i am operating a pc how can i solve this issue?
Message 8 of 9
jd
Community Visitor
Community Visitor
Thank you very much. It worked!!!!
Message 9 of 9
david.p.busch
Community Visitor
Community Visitor
Thanks! Much appreciated
