The software no more find a closed contour
patrice.saintot
patrice.saintot
I am not a beginner and generally ther is no problem at this level.
Here is a very simple document.
In is impossible for the sofware to find a closed contour !
There is no particular things is this schematics.
Were is the utility tool used to understand were is a mistake ??
Is is possible there is a bug in the latest version.
The file is in the following path:     Compteur / Piece
It is impossible to drag the file on this messages.
Faithfully,
Patrice
TheCADWhisperer
@patrice.saintot
When you Edit Sketch do you have Show Profile active?
patrice.saintot
I don't know what caused the problem.
The file was corrupted. I deleted it and re-create the same file and now it
is ok.
I will give you my general point of view:
*" the more you modify the software, the more windows bugs there are !! "*
The pc accepts less and less of this software, the original software had
no bugs.
Everything causes problems: as an example when I try to use the
software to copy a part of the screen, the window of this software cannot
live together with your software.
I can notice a lot of such problems...
Best regards,
Patrice
