Text gets rotated when moving it
FrodoLoggins
Advisor Advisor
FrodoLoggins
In the below video you'll see me move a text box. Half way through it decides to rotate the text as well. Happens when clicking on text box lines and moving them OR when using the move command. In the video the text gets rotated IN THE MIDDLE OF ME MOVING IT. The customer does  not want the text to be at an angle. I need to get some work done.
- Time Magazine’s Person of the Year 2006
- Apple M1 Max rMBP A2485 // Latest MacOS // Latest Fusion
- Usually working off files uploaded to Fusion as: Step, STL, SLDPRT. If it matters ask me.
jhackney1972
Sketch constraints are NOT automatically added to Text Boxes.  After placement, add a Horizontal sketch constraint to either the top or bottom line of the text box before dragging it around.
John Hackney, Retired
FrodoLoggins
Thanks so that fixes half my issue.
Now on to the second half:
You're saying when I click on this arrow:
You're saying it's by design that when I click on that arrow and drag, the text box will move in the axis I have selected and then randomly decide to move in a different constantly changing axis if I didn't add a horizontal constraint to the text box?
jhackney1972
If you are using the Move command only, you do not have to add the sketch constraint.  I only add it if I am going to drag it around as you did in your video.  I have never had any issues with moving a text box with the Move command as long as I am using the direction arrows.
g-andresen
just doubleclick and move without "movetool"
günther
FrodoLoggins
"If you are using the Move command only, you do not have to add the sketch constraint."
Ok good so another bug that won't get fixed.
