Switching Between Configurations Bug
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
While trying to implement configurations in my assembly, I tested switching configurations, and it didn't change any of the parts. I was using configured parameters to adjust angles and distances in 'pin-slot' and 'revolute' joints. I had two configs, one had the parameters set to 0, and the other had them set to the required angle/distances. When I switch between the configs, no changes are made. When I check the joints, they weren't set to the parameters (despite setting them to said parameter(s)), instead the joints were set to the value of the configuration I switched from.
Config 1: just after I set the joint to the configured parameter (-3.825")
(not letting me upload other screenshoots)
Config 2: assembly/joint remained in the same position, until i enter the joint and re-enter the parameter
Switch back to config 1: Joint is now set to 0in (the value of config 2 parameter) instead of the parameter
