Switching Between Configurations Bug
20017182
Observer Observer
20017182
Observer
Observer
While trying to implement configurations in my assembly, I tested switching configurations, and it didn't change any of the parts. I was using configured parameters to adjust angles and distances in 'pin-slot' and 'revolute' joints. I had two configs, one had the parameters set to 0, and the other had them set to the required angle/distances. When I switch between the configs, no changes are made. When I check the joints, they weren't set to the parameters (despite setting them to said parameter(s)), instead the joints were set to the value of the configuration I switched from.
20017182_0-1771098967379.pngConfig 1: just after I set the joint to the configured parameter (-3.825")
(not letting me upload other screenshoots)
Config 2: assembly/joint remained in the same position, until i enter the joint and re-enter the parameter
Switch back to config 1: Joint is now set to 0in (the value of config 2 parameter) instead of the parameter
mayank.malukani
Hi @20017182 , Thank you for reaching out, I wanted to understand a bit more about what exactly was configured. Was it the the offset values of the pin slot joint?
TrippyLighting
This is impossible to troubleshot without the design.
If you can share it, please export it as a .f3z or .f3d and attach it to a post.
lauri_barnhart
Hi @20017182,
I wanted to check in and see if you saw @mayank.malukani and @TrippyLighting's follow up questions and you still needed assistance, or if you found a solution to your question already? Please share any available screenshots or screen recordings so the community can assist you further.
All the best,
Lauri | Community Manager
