Sweep intersect itself error
Message 1 of 17
I am creating a really simple phone case. I want to sweep my shape around the "phone shape". The problem I'm getting is that the shape will intersect itself on the corners, which I understand, but is there a way of sweeping anyway? Is there an option to just 'blend' the intersect into the design per se. I have added some screenshot below, as well as a screenshot of what I want to achieve. Any help is appreciated.
Iwan
Replies (16)
Message 2 of 17
TheCADWhisperer
File>Export and then Attach the *.f3d file here.
I would probably create as a solid and then Shell or as a surface and then Thicken.
Message 3 of 17
jeff_strater
a solid sweep cannot self-intersect, and there is no way around that in Sweep.  Listen to @TheCADWhisperer for better approaches.
Jeff Strater
Engineering Director
Message 4 of 17
Thank you! Curious to see what you come up with.
Message 5 of 17
TheCADWhisperer
You have some pretty "rough" splines in your sketches.
Message 6 of 17
Yes, correct.
Message 7 of 17
Did you manage to overcome this problem? I cannot open your file because (I think) I have a student version, and Fusion is asking me to update, but there are not updates available it seems.
thanks
Message 8 of 17
Hi again,
Okay, so from your comment, I re-drew the rectangle, then used the circle tool to create the corners. This worked, thanks.
The reason I didn't do this first time, is that I wasn't sure if the corners had a constant radius'. I hope that makes sense. See image attached.
To add, do you know why a 'rough' spline wouldn't work? I've seen tutorials online of a Loft working fine on a Spline similar to mine.
Thanks again for the help
Message 9 of 17
TheCADWhisperer
Make the splines tangent continuous and they will work fine.
Use as few points in the spline as possible (yours need only beginning point and ending point and tangent).
Message 10 of 17
TheCADWhisperer
@Anonymous wrote:
 I have a student version, ... but there are not updates available it seems.
Any issues have nothing to do with your license being a student license. Are you running on Mac or are you running on Windows machine.
If Windows, search your machine for file named Fusion 360 Client Downloader*.exe
Message 11 of 17
TheCADWhisperer
This spline is particularly poor quality...
Message 12 of 17
Message 13 of 17
GRSnyder
@jeff_strater wrote: a solid sweep cannot self-intersect, and there is no way around that in Sweep.
@jeff_strater, is this not a self-intersecting Sweep?
Here it is as a pattern of extrusions along the same path, which shows the intersection more clearly:
I'm sure the limitation has something to do with intersecting geometry, but it must be something more specific than just "two 'stations' of the swept profile cannot claim the same point in 3D space". No?
Edit: In fact, even this self-interpenetrating result seems to be allowed :
Message 14 of 17
jeff_strater
@GRSnyder - you are definitely right.  Apparently, my information was sorely outdated.  What seems to be the case is purely analytic geometry (lines and arcs) seems to allow self-intersections, but a more complex path, like a spline, does still have this restriction.  I do remember, now that you mention it, hearing about a kernel improvement a while back that would allow self-intersections in some cases.  I apologize for the misinformation...
Jeff Strater
Message 15 of 17
GRSnyder
Thanks, @jeff_strater, good to know!
The case that set me on the path of investigating this does indeed involve splines, both for the profile and the rail. So it's entirely plausible that this might still be the important distinction. It's a confusing problem to run into because the error message explicitly talks about the issue being self-intersection, and yet the canonical example of a Sweep is often something like the 90 degree pipe bend shown above.
Message 16 of 17
r.mitschke
Maybe you can try to use the sweep command in the surface tab instead of creating a solid. I believe that surfaces can self-intersect, while solids cannot.
Message 17 of 17
Imonacomputer2004
Observer
Observer
(Sorry to necro)
This just saved some of my already thinning hair. Wanted to ignore a sweep in which the path was too curvy for Fusion's liking. Made the sweep with a surface rather than a solid, split the body with the resulting surface, and removed the unwanted portion. Thanks!
