suddenly unable to select a component to combine
tio.a
Message 1 of 54
tio.a
 looked around for others that might have the same issue, and the most i can find are some tips on selection filters.   the components are not set to not-selectable.
i'm unable to select components for combination in older models where i was previously able. all models are affected, so i looked for other global settings that might turn off selection for the combine-tool.  nothing leaped out at me.
i'd be really thankful for a tip here.
Replies (53)
Message 21 of 54
jhackney1972
You file works just fine.  I would make sure you have your selection filters on.  Just a guess.
John Hackney, Retired
Message 22 of 54
tio.a
my selection filters include all selectables
Message 23 of 54
jhackney1972
Try something for me,  with NO command running, you should be able to highlight bodies and components in your design space and Browser.  Can You?  If not, you have a bigger problem than Combine.
Message 24 of 54
tio.a
i can.
take a look:
Message 25 of 54
tio.a
but combining?
selection is off limits
Message 26 of 54
jhackney1972
I think it is time to visit the Fusion 360 Service Utility and do a Repair.  Make sure all other applications are closed when you do this and maybe even consider disabling your Anti-Virus during the process.
Message 27 of 54
tio.a
i don't use antivirus.
i did the repair.
issue persists.
Message 28 of 54
TheCADWhisperer
I am not sure if we already covered this step...
If you create a brand new file with two simple bodies - does the behavior persist in that new file?
Message 29 of 54
jhackney1972
I am out of suggestions as well.  I hope you find the issue soon.  If you do, post it back, I would love to know what it was.
Message 30 of 54
tio.a
yes, this was tried.
new file.
cylinder, box.
drag n drop, move, ... all work. selection is not an issue.
combine: can't select targets
Message 31 of 54
tio.a
looks pretty hopeless:
tried to use the utility to uninstall.
i'm directed to a webpage that asks me why.
i close that, as instructed in order to proceed with uninstall.
nothing happens.
if i clickopen the fusion 360 app, it says that the latest is already installed. which definitely tells me the uninstall didn't work.
issues persists.
then i created another account using another email, hoping for a fresh install.
asks me if i want to use the latest version already installed.
clicking no: nothing happens.
clicking yes: issue persists.
sadly, i can no longer use fusion 360. have to move to another product.
thanks for all your help anyway.
Message 32 of 54
liveKZAY4
Observer
Observer
i went to another computer entirely:
created a different account at autodesk.
installed fusion 360.
am able to select targets for combine action.
i think if fusion could actually be uninstalled from the device where it isn't working, i could get it working there, which is my device that i use for everything else i do, and is mobile.
but that's the problem now it seems.
so the solution, i think, is to go nuclear: uninstall fusion 360 and re-install.
but the uninstall process goes nowhere after i answer the survey about about why i want to uninstall.
how do i uninstall fusion 360. ?
Message 33 of 54
liveKZAY4
Observer
Observer
i spoke too soon.
i closed fusion 360 after it installed and ran properly.
restarting fusion 360 brings me to login again.
i use the credentials that were successful previously and am greeted by a prompt to create- or join-a-team.
both options are disabled. there is no option for except to go back.
sadly, i really have no more time to deal with this anymore.
i've begun my subscription to another 3d tool.
thanks for your time.
regards.
Message 34 of 54
g-andresen
start a CLEAN UNINSTALL
günther
Message 35 of 54
liveKZAY4
Observer
Observer
i thought that's what the uninstall option in the utility does.
is there a different link else where for a "clean uninstall" ?
Message 36 of 54
liveKZAY4
Observer
Observer
there is no option for a "clean uninstall" in fusion360.app's package contents.
i can't proceed past the select-or-create-a-team dialogue because both options are disabled.
Message 37 of 54
g-andresen
try this
or maybe the attached Cleaner
günther
Message 38 of 54
tio.a
here's my attempt to uninstall:
Message 39 of 54
tio.a
this uninstaller.zip is for an .exe
i have been running on macos.
do you have an uninstaller for macos?
Message 40 of 54
g-andresen
1. maybe another user has the MAC version
2. the manual CLEAN method of the utilities is also an alternative.
3. I always keep a 2nd user profile (system) with a fusion installation (same account) for such cases.
günther
