Announcements
We are currently experiencing an issue impacting some Autodesk Products and Services - please refer to the Autodesk Health Dashboard for updates.
suddenly unable to select a component to combine
tio.a
Message 1 of 54
tio.a
 looked around for others that might have the same issue, and the most i can find are some tips on selection filters.   the components are not set to not-selectable.
i'm unable to select components for combination in older models where i was previously able. all models are affected, so i looked for other global settings that might turn off selection for the combine-tool.  nothing leaped out at me.
i'd be really thankful for a tip here.
Replies (53)
Message 2 of 54
TheCADWhisperer
Is the Component berende active?
Can you show image with the sub-nodes expanded.
Message 3 of 54
jhackney1972
We really need your model to troubleshoot your issue.  Open your model in Fusion 360, select the File menu, then Export and save to your hard drive.  Attach your model to a Forum reply.
John Hackney, Retired
Message 4 of 54
g-andresen
Combining is done for bodies not for components.
What happens when you open the corresponding components in the browser and then select the bodies there?
Please share the file.
File > export > save as f3d on local drive  > attach it to the next post.
günther
Message 5 of 54
tio.a
Screen Shot 2022-09-11 at 7.01.10 AM.pngmoved the model to a file of its own. issue persists. here the screen cap i think you're asking for.
Message 6 of 54
tio.a
moved model to file of its own. issue persists.
Message 7 of 54
jhackney1972
No, the Forum users are looking for the actual model, not a screen capture.  Go back to one of the previous post and see how to attach your MODEL to your post.
Message 8 of 54
TheCADWhisperer
@tio.a wrote:
... here the screen cap i think you're asking for.
Of course I was expecting you to drill all the way down...
This should have been understood...
If you drill ALL of the way down are the Bodies marked as un-selectable as shown in image above?  (red circle and line - not symbol)
Can you post screenshot similar to this...
Have you rebooted the computer and the issue persists?
I cannot reproduce the issue using your file.
Message 9 of 54
tio.a
Message 10 of 54
tio.a
yes, i saw that after i sent it.
sent another one, tried selecting the individual bodies for combine.
Message 11 of 54
jhackney1972
You have created the three bodies, you want to combine, each in a different component.  Move the two bodies, from the second two components to the first, by dragging the bodies in the Browser and then the Combine will succeed.  Model is attached.
Message 12 of 54
tio.a
Message 13 of 54
TheCADWhisperer
@jhackney1972 wrote:
 Move the two bodies, from the second two components to the first...
@jhackney1972
I can select and Combine in any scenario - I cannot reproduce the issue as shown in the OPs videos.
Message 14 of 54
tio.a
screenshot of selection filters
Message 15 of 54
jhackney1972
I agree with you, I could combine the bodies in separate components also.  The combine is going to place the final body in the component you started with, when selecting bodies, and removing them from the other components so I thought I would clean it up for him ahead of time.
Message 16 of 54
TheCADWhisperer
Ah, there's your problem.  (Just kidding.)
Have you rebooted the computer.
Message 17 of 54
tio.a
trying this again. doesn't look like it went through
Message 18 of 54
tio.a
i rebooted twice .
restarted fusion twice
there are no other screens or pointing devices attached to my laptop.
and it's been the same laptop i've always used successfully for fusion
selection continues to work for all other functions, like move.
Message 19 of 54
TheCADWhisperer
I am stumped - I'll leave it to the #1 expert to figure out.
Congratulations John... 😎
Message 20 of 54
tio.a
yes, i used to be able to combine bodies from different components as you describe with the good result.
now, when i click to select anything to combine, i THINK the mouse click registers because it triggers the tooltip: select target..
