student web brower access, Sign in failure
joonyoung2022autodesk
Observer Observer
Observer
Observer
sign in failure.jpgI am currently using fusion 360 with student licence on web(safari) browser (ipad)
Until today, Fusion 360 worked well.
My Ipad battery was out and my web fusion 360 connection was lost.
After reboot, I see above message and cannot start fusion 360. I can use fusion360 on PC with same ID without error but I need web access desperately.
Please help, I need support. Thank you.
sutherland-
Hi @joonyoung2022autodesk
Could you try resetting your password for your Autodesk ID and see if that helps?
Please click on Accept Solution so other community members can see how to solve the issue.
Also, consider giving a Like to the comments that you feel helped you.
Best regards,
Level  sutherland-
Member
Observer
Observer
hi sutherland. I tried changing password but is still having the same issue...wonder why it is happening...
sutherland-
Does turning off cellular data or the analytics options in Settings > Fusion 360 (mobile app) help?
If all else fails, try uninstalling and reinstalling.
I should mention that there is also an A360 mobile app that provides similar functionality. It'd be interesting to see if you have the same problem with both apps.
Best regards,
Level  sutherland-
Member
HughesTooling
@joonyoung2022autodesk  Did you click the link on the error to possible solutions? Have you tried clearing all the cookies for the sign in page? Not sure how you do that on an iPad. Or can you try a different browser?
Mark
Mark Hughes
Owner, Hughes Tooling
