stl file export and image file import problem
jerrybaffetto
Message 1 of 29
jerrybaffetto
from two days F360 goes continuously in craxh
I can't export stl files, when it opens the window to save the file the program stops and crashes.
I tried to do a clean reinstallation, nothing has changed.
i updated the drivers of the video card, nothing has changed
please, i ask for your help.
thanks
Replies (28)
Message 21 of 29
pascalfritz71
Thank you, I am having the same problem! exporting to a new folder seems to work. hope that helps you guys figure this out.. also if you try to replace an already saved stl by exporting fusion crashes. You can try deleting the stl from your folder, that did the trick for me
Message 22 of 29
lance.carocci
It is not likely to be related to the creation of a Team Hub. It also seems to be crashing with different STL software, no particular application.
As for your Preferences - sometimes Fusion needs to download you preferences the first time you sign in, but should appear after a restart. If the preferences are not saving between application sessions, we may need to check your logs to look for any errors.
Out of curiosity, could you please try the steps from this post and confirm if the crash still happens?
Lance Carocci
Fusion QA for UI Framework/Cloud Workflows, and fervent cat enthusiast
Message 23 of 29
jerrybaffetto
hi Lance
I have already done all the steps you recommended in the other post.
my pc has a Nvidia Geforce RTX 2060 video card
i have updated the drivers
and apparently i'm reading that many users have the same problem as me with F360
Message 24 of 29
lance.carocci
Yes, this issue has been difficult to reproduce. The current theory is that it's something related to the default STL handler, which in turn is responsible for generating thumbnail icon previews. I think the thumbnail generation might be the issue here, but it's unclear to me why it started now and what is in common between affected users.
Lance Carocci
Message 25 of 29
lance.carocci
@jerrybaffetto do you have Chitubox installed? We have confirmed the crash when Chitubox is set as the default handler for STLs, and generating thumbnail icons for Windows Explorer.
If you have this installed, please try uninstalling it and see if the crash continues.
Lance Carocci
Message 26 of 29
jerrybaffetto
hi Lance
yes, I've been using chitubox forever and I've been using fusion forever, I don't think that's the problem. (I also use SF3d, Tronxy slicer and Idea maker)
besides i can't even import image files to fusion...
Message 27 of 29
lance.carocci
@jerrybaffetto we have only been able to reproduce this crash with Chitubox installed. For the moment, this seems to be the quickest workaround to Explorer crashing Fusion 360.
Lance Carocci
Message 28 of 29
jerrybaffetto
ok Lance, thank you for assistance
Message 29 of 29
Phil.E
Update: A likely cause has been identified. Please help confirm.
See message 15 here.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
