STL export Issues?
STL export Issues?
STL export Issues?
Hi Community,
are there any STL export issues since the latest update?
whan I hit the "save to STL" on a component, it takes forever to open the file dialog box...
sometimes up to 5 minutes.
This started at the latest update on fusion 360, I have had no problems with the versions before.
regards
Dennis
HughesTooling
I've not noticed anything different, is it the same with a simple cube? Have you accidently set the mesh option to a very accurate\fine mesh?
Mark
Mark Hughes
Owner, Hughes Tooling
jeff_strater
I can validate what @HughesTooling says.  There have been no changes to the STL export capability in quite a while.  Are you sure that you are not operating on a very complex object, or as Mark says, have the precision set very fine?  It can certainly take some time to compute the faceting in a large model.  Also, do you have "Preview" enabled?  That will also have some performance impact.
Jeff Strater
Engineering Director
