export from slicer to .stl
Is it possible to export the interlocked slices together as one object in an .stl file?
I only see the option to save a 3DMK but i would like to 3D print the panels in one group.
wmhazzard
If all of your bodies are in one component then right click on the component and you can save all bodies as one STL. If your bodies are in different components then right click on the top level and all bodies that are in your assembly will be saved as one STL.
Thank you for your suggestion, but that doesn't appear to work in the Slicer application.
I should have made it more clear that i'm looking for a way to export .stl from the 'Slicer for Fusion 360 application', sorry for that 🙂
wmhazzard
Clarity in questions always helps. I am pretty sure that you can not export STL's from Slicer, it is designed for routers and lasers.
Thanks. It would be a great feature though
