Splitting Problem
Splitting Problem
Splitting Problem
I have been successfully splitting a yacht hull body for 3D printing and then removing the body not required. Suddenly although the split body appears to work when I try to remove the unwanted part it doesn't go. However if I drag the whole hull it leaves the part I want but I end up with two bodies although it only says one body. Any ideas please
TrippyLighting
Please share you model. (export as .f3d and attach to post)
File attached. I split at 200mm from the bow
TrippyLighting
You are using way too many spine points. I'd venture a guess that most of this curves need a maximum of three.
That results in better surfaces and such problems as splitting disappear.
TrippyLighting
Im am not sure I understand the problem. You have two bodies that box have the same geometry.
Can you make a screencast and explain you problem in more detail ?
Thanks everyone for your interest in my problem. I reverted to an earlier version and it splits OK so don,t know what the problem was but all working fine now
