Cannot save files
Cannot save files
Cannot save files
I am very inexperience with Fusion 360 and only try to use it very occasionally.
After updating to the latest version today, I am unable to save my file.
The Export - Save as copy and Save as STL options are not available and are greyed out.
I noticed that at the top of my screen it says Term expired, could this have something to do with this problem and why would it be expired.
I was lead to believe that this software was free to use for hobbyist.
Any help or advice on how to resolve this issue would be appreciated.
I have read through several posts on the subject via the search option but am unable to resolve this issue.
jhackney1972
Read through this article completely, it should get you past the "Term Expired" problem.  The first response by the Autodesk Representative gives the process and the second one explains about the "Term Expired" icon.
John Hackney, Retired
Problem solved.
Thank you so much for your help.
jhackney1972
Please mark your forum question solved to remove it from the list and also make it available for others to find and use as a solution.
