Some bodies in design do not highlight when selected...
eric_gunnerson
eric_gunnerson
I have a simple design with just a few cylinders and blocks. All bodies, no components, nothing weird.
Two of my bodies do not highlight in the model when they are selected - no blue selection. I can click on them in the browser and they select - I can perform operations on them - but they do not highlight. All the others highlight.
I did a split on one of them, and the old body does not highlight, but the new one does.
jhackney1972
Can you record a Screencast to show others this behavior and also share your model?
John Hackney, Retired
damionrushton
I'm having the same problem.
Before splitting, the component is completely selectable.
Whereas the body isn't?
after splitting: the bottom isn't highlighted.
but the top is:
I also had problems renaming the bottom until I hid the "top", box selected the "bottom" and then renamed it???
prior to that, renaming would revert back to "body 1".
I can extrude the bottom but not move it as though it has been grounded, but there is no grounded option.
Also if I make the "top" <selctable/unselectable> I get the red marker next to the "top" body:
Whereas the "bottom" body just turns grey when unselectable:
jeff_strater
that design seems to work OK for me.  See attached video.  Maybe try closing down Fusion and re-starting it?
Jeff Strater
Engineering Director
damionrushton
Why didn't I think of that 🤔
Thank you for the quick response.
