Solver Error (local)
davidPR52T
davidPR52T
I had to do a clean install yesterday after a windows update (OS Build 19041.928) seemed to break fusion. I basically got an error saying you are offline despite having internet connection which worked fine. Anyway clean install fixed that issue but I then went to try a very simple static stress analysis problem and the simulation fails everytime.
At first I thought maybe the part is just way to weak... So i reduced the force right down to 5N and removed the hollowed out structure (i tend to simulate 3d printed parts as hollow with a thickness of the solid walls, this gives conservative analysis results) but still i get a failure and a pretty useless failure message.
picture of the setup below. single part subjected to compression load and fixed on one side. I've also attached a screenshot of the error dialog in fusion as well as the error log file. As you can see i tried a whole bunch of variations to try get it to solve. It always meshes fine then just instantly fails at the solving stage.
dsouzasujay
Hi @davidPR52T ,
Can you give a try solving on Cloud?
Let me know if that works.
If it still fails then export by File>Export *.f3d/*.f3d file to your local drive and then Attach it here to a Reply.
If my answer helped, please 'Accept Solution'
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
davidPR52T
I have just tried the Cloud solve (I'll admit i try to avoid that as I have very limited cloud credits available which i try to save for studies which cannot be done locally!) and it worked straight away.
Note i reverted back to the actual study i wanted to do with the hollowed out structure and the correct 188N load.
I then modified the load by 1N so that it would let me try a local solve and i get an instant failure on the solving phase again.
dsouzasujay
Hi @davidPR52T ,
Can you check and provide below details?
  1. Go to
    • C:\Users\<USERNAME>\AppData\Local\Autodesk\webdeploy\production\<Alpha Numeric digits>\NASTRANSolver
    • Check if you have files in it.
  2. In Windows, select Start  and enter dxdiag into the search box on the taskbar.
    • Attach the DxDiag.txt to the next reply
  3. Export by File>Export *.f3d/*.f3d file to your local drive and then Attach it here to a Reply.
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
davidPR52T
Thank you for your assistance, please see responses below in bold.
  1. Go to
    • C:\Users\<USERNAME>\AppData\Local\Autodesk\webdeploy\production\<Alpha Numeric digits>\NASTRANSolver I don't have the folder at all?
    • Check if you have files in it. ^
    • Attach the DxDiag.txt to the next reply Attached
  3. Export by File>Export *.f3d/*.f3d file to your local drive and then Attach it here to a Reply. Attached
dsouzasujay
Hi @davidPR52T ,
Apologise for responding late.
  1. Go to
Can you try finding the NASTRANSolver folder in below location or somewhere in C Drive?
C:\Users\***\AppData\Local\Autodesk\webdeploy
If you can't find the NASTRANSolver folder then Nastran package is not installed successfully, So you cant solve simulation studies locally.
I was able to solve the study successfully.
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
