So my pc can't run fusion anymore. I'll buy a laptop.
Message 1 of 11
Is this specs good enough for fusion? My pc just stopped working properly for no apparent reason. Please see attached file. Thank you!
Replies (10)
Message 2 of 11
seth.madore
It will depend greatly on what your intent is with Fusion. Intense assemblies and photo quality local renders? Or more "dubbing around" type stuff, maybe some light 3d modeling and printing, occasional CAM toolpaths?
We do have a System Specs sheet: https://knowledge.autodesk.com/support/fusion-360/learn-explore/caas/sfdcarticles/sfdcarticles/Syste...
Seth Madore
Message 3 of 11
For importing 3d models, editing them and then printing them, I don't need to render them on fusion. Is That specs for a laptop enough sir?
Message 4 of 11
seth.madore
Technically, yes. But truthfully, I'd want to search out something a bit more powerful if I had the cash to do so.
Are you set on a laptop? For the same amount of money, you can often get a PC that's quite a bit more powerful
Seth Madore
Message 5 of 11
g-andresen
1. All you need >> CPU Speed
2. Number of cores >> unimportant
3. RAM > 8 GB
4. Graphic > Direct X low/midrange
günther
Message 6 of 11
Yes I can build a pc much stronger with my budget, but I require a laptop because I'm not home most of the time and I like to model everyone and then. I'm super confused because I don't know anything about laptops. Thank you man
Message 7 of 11
Thank you, I think the specs I posted is enough based on you post.
Message 8 of 11
Btw this is the specs of my desktop that just stopped fusion from working properly.
Message 9 of 11
mcd540
More cores seem to help for rendering.
Message 10 of 11
lance.carocci
@Anonymous this device should be more than sufficient for Fusion 360. What is the behavior you are experiencing?
Lance Carocci
Fusion QA for UI Framework/Cloud Workflows, and fervent cat enthusiast
Message 11 of 11
g-andresen
As long as you don't know which action with which design causes the state of your desktop system, it makes no sense to comment on the suitability of a new (better) system.
günther
