Part not animating outside of edit menu
I am trying to create a swinging door hinge. I have jointed the parts together with the revolute tool. In the edit menu it animates perfectly and is what I am looking for. But, as soon as click "okay" and exit the part will not rotate or animate.
If anyone can help me with this it will be greatly appreciated.
jhackney1972
A video shows what you have and want. the forum users need your model to show you what you need to do.  Please attach it.  If you do not know how to attach your model, open it in Fusion360, select the File menu and then choose Export and save the .F3D file to your hard drive. Then use the Attachments section of a reply forum post to attach it.
John Hackney, Retired
I have just edited and attached it
jhackney1972
I do not know what was wrong with your Revolve joint.  All I did was replace it and all is well.  Model is attached.
laughingcreek
just turning on "capture design history" on your original file makes it work like your expecting it to.
interesting hinge, is there a design reason for the leaf to be mounted backward from the way a typical butt hinge would be made?
