Slicer for Fusion, Slices to thick
jako_thehoff
Observer Observer
jako_thehoff
Observer
Observer
I want to create a model with slicer for fusion. Using Interlocked Slices. The problem is, that the slices are not precisely stacked above. They are like a few mm touching. Thats bad, because i cant stick them all together into the 2nd Axis. The material thickness is 4mm. When i measured the 2nd Axis, the thickness of the slots is just 3,39mm. That means, the parts wont fit?
Whats the problem here?
On the picture, you see them touching inside and not even....
seth.madore
Are you referring to the old Slicer software? That's been long deprecated and no longer supported
Seth Madore
jako_thehoff
Observer
Observer
Yes i know, but i still using it, need help in this case. How to make the Slices even on top
