Sketch Anomaly
Sketch Anomaly
TheCADWhisperer
Consultant Consultant
Sketch Anomaly
TheCADWhisperer
OK, I have been away from Fusion for a while and getting back into the arena...
Why does Sketch2 not show as fully defined?
jhackney1972
The only thing I can find is the Midpoint constrain, to the Origin point, was not successful in your sketch.  If you remove it and then replace it, everything is find.  Cannot give you a good reason for the first one not succeeding.
John Hackney, Retired
TheCADWhisperer
@jhackney1972
Hmmm, I tried from scratch in a new file and everything worked as expected.
Not sure what I did in the original attempt, and whatever it was - it should still solve correctly.
