Sign in via browser on fusion 360, doesn't open browser.
unordmtlr
Message 1 of 75
unordmtlr
I had a problem today when opening the software. The software asked me to sign in via a browser, which it was supposed to direct me to, but no browser window popped up. Instead, I was left with no way to log in.
I've tried:
  • repairing and reinstalling the software
  • running the software as an administrator
  • trying a different network
  • changing the main browser
OS: Windows 11
Replies (74)
Message 61 of 75
ramahilfama
Community Visitor
Community Visitor
@hlfma_rama
Message 62 of 75
moviladani
Observer
Observer
well then i guess welcome to the community of users who are getting f* by autodesk troubleshooting non-existent support team
Message 63 of 75
TimofeyBiryukov
For me, the solution after the longest time was in the link opening software.
I've had a program installed that would let me open different websites in different browsers. It's set as a default browser and hijacks all the links that you click in windows. That software had issues with long, complex OAuth links that fusion360 tries to open when logging in.
Changing a default browser to be straight up regular browser fixed my issue.
Message 64 of 75
berdogral
Community Visitor
Community Visitor
None of the above works. I think it is time to switch the programs
Message 65 of 75
ziadmax2
Community Visitor
Community Visitor
Thank youuuuu my heroo
Message 66 of 75
bnsnlai
Community Visitor
Community Visitor
Mine is stuck here and when i click sign in, no browser is launched and i am stuck. Cannot open fusion 360, please help
Message 67 of 75
hhansen30
Observer
Observer
I cant believe that this issue has been happening for such a long time to so many people yet Autodesk still uses their flawed sign in. Shows you how much they dont really give a f#$& as log as they get their money. Typical corporation. I had this issue last year and I stopped using Fusion . Thought by now they would have fixed their mistake. Installed Fusion again and again still having the same issue. Amazing.
Message 68 of 75
Naureka
This browser autenthication "feature" is something that I really can't understand. There must be some logic behind it, but it's vague to me as I'm just an ordinary user, not a software dev. There was nothing wrong with previous authentication method. Now every sign in is a russian roulette.
On my systems I use Firefox as the main browser and signing in is impossible there I need to maintain a secondary separate browser on every system just to be able to sign in to Fusion. Every time I got logged out I have to change my default browser in my system and pray. This in nowhere close to being convinient.
Message 69 of 75
daniel_t_bullock
Community Visitor
Community Visitor
SOLUTION - (that worked for me)
I was using Google chrome without issues for 3+ years until to sign in to Fusion. Stopped working.
Solution use Microsoft edge and made default browser
Message 70 of 75
01fe23bar007
Community Visitor
Community Visitor
same happen with me any solutions ??
Message 71 of 75
njain59A6Q
Community Visitor
Community Visitor
I tried all of the above and still it doesn't work. What should I do?
Message 72 of 75
WastedHoursOnAutodesk
Observer
Observer
I had the same issue but resolved it. This bug has been around since at least 2023, and Autodesk still did not solved it. So I’m posting this solution for future generations. I hope it helps someone.
Here’s what I did:
1. Download the Autodesk Identity Manager.
2. Follow the installation prompts until the process is complete.
3. Navigate to Settings > Apps > Installed Apps > Autodesk Fusion > Modify > Repair.
After these steps, the Sign-In window opened successfully.
Horrible software, horrible company. I don’t recommend it.
Message 73 of 75
dinko_90
Community Visitor
Community Visitor
Hey guys!
I’m having the exact same problem! I’ve tried absolutely everything, read through this entire thread and every single comment from you all — and still no luck! I even reinstalled my entire Windows system just because of this stupid program, and guess what? It worked for 2-3 days after that, and then Fusion 360 stopped opening the browser again (I tried 7 or 8 different browsers with different settings). I’m honestly frustrated beyond belief and I do NOT recommend this software at all!
I’ve been trying to solve this issue for over a month now, but no success whatsoever.
Leaving this message here for future readers:
PLEASE DO NOT USE THIS SOFTWARE! AND DO NOT RECOMMEND IT TO YOUR FRIENDS!
Message 74 of 75
ahmadbinsameerpt
Community Visitor
Community Visitor
guys my identity manager is not even running in task manager and i tried to run it manually by cliking the .exe file which just gave error saying it cant find that file even tho i am clicking it. and yes i do also have the sign in problem
Message 75 of 75
martin240895
Community Visitor
Community Visitor
This didn't worked for me. I was able to fix it by re-insatlling "Autodesk Identity Manager" :
https://www.autodesk.com/fr/support/technical/article/caas/tsarticles/tsarticles/FRA/ts/7zbgTemIhA3l...
