Sheet metal flat referencing wrong part in drawing
MattiMobi
Message 1 of 10
MattiMobi
I found a similar issue from 2020 that has not gotten any replies, so I will try again as I see this as an critical bug.
I have an assembly where I have 2 parts (hereafter named Part1 and Part2) and other sub-assemblies. These two parts are originally from the same part, but copied and changed lengths.
When I created a drawing of this complete assembly, I try right clicking Part1 to create a drawing into my assembly drawing of this part as flat pattern. I choose which sheet to place it in and it works.
However, when I try this exact process on Part2 it refrence Part1 as flat pattern instead.
I believe this is an bug that needs to be solved. However, if there is something that I do wrong, please enlighten me.
Replies (9)
Message 2 of 10
ClintBrown3D
Hi @MattiMobi
I’m sorry to hear that you are having trouble. I’d like the team to take a closer look for you.
Please share a downloadable link to your drawing, so that I can ask the team to investigate this, or if it is sensitive, feel free to send it directly to me Fusion.360.Drawings{a}Autodesk.com, with a reference to forum post.
Clint Brown
Senior Product Manager - Autodesk Fusion
Book some time on my calendar
The Ultimate Guide to Drawing Automation
Message 3 of 10
MattiMobi
Thank you for looking into this Clint!
I have sent you an Email with link to drawing and referenced this forum post
Message 4 of 10
MattiMobi
I just got the email in return saying that you cannot receive emails from my email
Message 5 of 10
ClintBrown3D
That's weird, send it to me then Clint. Brown {a} Autodesk.com
Clint Brown
Message 6 of 10
MattiMobi
I have sent you a new email to your specified address
Message 7 of 10
ClintBrown3D
Thank you, we have the files, we will investigate and come back to you with any questions.
Clint Brown
Message 8 of 10
-KyleWilliams-
Thanks for reporting this issue to us. We were able to reproduce this and the team is working on a ticket for this issue, we have it logged as FDWG-16451.
Kyle Williams
Senior Customer Advocacy Manager - Design and Documentation
Ontario, Canada
Become an Autodesk Fusion Insider
Message 9 of 10
MattiMobi
Thank you Kyle.
Hope to hear from you soon with a solution
Message 10 of 10
louisdavid_fili
Community Visitor
Community Visitor
I had the same issue, all I did was deleting the flat layout in both part and remaking one.
I looks like it only happens when a part is a copy of the other one that already had a flat layout created.
