sheet metal flat patern design changes does not update in solid model
appiek
appiek
Hi.
I have been wondering if i am doing something wrong. I designed a cone shaped sheet metal part. Made a flat pattern and then did some design changes in the flat pattern enviroment. when i click finish flat pattern. the changes does not update to the unfolded state. Is there something i am missing.
jhackney1972
Flat pattern changed do not propagate back to the model.  Use Unfold ->Refold commands.  Changes to a flat after an Unfold will propagate back to the model when you Refold.
John Hackney, Retired
appiek
Thanks learned something new.
