Self paced learning question!
ilheung33
ilheung33
I'm learning fusion 360 through self paced learning material in this website. Nowadays, I'm stuck in a tutorial.
If you go to Fusion 360>Resources>Product Documentaion>Design:Solid>Tutorial, there is "Creating features from sketches tutorial" under Tutorial Organization category. If I click this link and click again "Activity: Sweep, extrude, and revolve from sketches" link, I can do the tutorial.
In this tutorial(trumpet), when I try to select for guide rail(#1, e), I couldn't select the two left segments. I followed the instruction, but it doesn't work.
Could anyone give me a solution for how to select them?
g-andresen
1. Please share the file.
File > export > save as f3d on local drive  > attach it to the next post
2. Which feature xx (sketch xx) are you talking about
günther
jhackney1972
Please add the URL, of your tutorial in question, to your post.  The link icon in the menu bar can be used for this task.  It is the one to the right of the smiley face.
John Hackney, Retired
ilheung33
This is the URL I was doing.
Fusion 360 Help | Activity: Sweep, extrude, and revolve from sketches | Autodesk
Let me know after you try the tutorial.
jhackney1972
Thanks for the link, it really help to give a clear and quick answer.  The Screencast will walk you through the process.  My guess is you are missing the selection of the multiple segments of both or one of the Path or Rail.  I attached my model for your inspection.
