Scaling Issues with 1:1 scaling print
Canwin1
Canwin1
Hi there, I have printed a 1in x and y square and when I go into design and choose 1:1 scale and then click print.
I check the paper and its printing at .975 of 1 inch. What is causing this?
But if I export the pdf and print it in chrome its the correct size. what gives?
ahreum.ryu
Autodesk Support
Autodesk Support
Hi @Canwin1
Thank you for your posting!
I think it's because of drawing size.
for example, The SheetSize A is 8.5 in x 11 in which is a Letter size in the print option. However, the real paper size is 8.26in*11.69in (210mm*297mm)
I tested it with "mm" which means I did fit the Fusion drawing size and real paper size and it's the same as I expected.
Please let me know if I misunderstand.
Many thanks,
Ahreum.
Canwin1
where did you find these print settings?
Canwin1
drawing size? its 1inch exact on x axis and 1 inch on y axis, I changed my printer preferences under device settings to the mm specs you have provided and still incorrect.
ahreum.ryu
Autodesk Support
Autodesk Support
Hi @Canwin1
Thank you for your reply.
In my case, I create a new drawing which has the A4 mm.
And then, I did set the print setting. Here is the result. The setting properties will be different depending on the printmaker.
If you can't resolve it, Please share your drawing file I will test it on my side. Here is how to share it
Many thanks,
Ahreum.
edwardsc3
Canwin1, you are correct and Fusion is printing at an incorrect scale. I did some testing at posted it to https://forums.autodesk.com/t5/fusion-360-design-validate/1-1-scale-in-drawings-is-actually-96-3-eve... and even included a comparison with a different sketching program.
I'm using the 8.5"x11" pages (and printer settings), and I measure it as 96.4% rather than 100%. I think you will encounter this problem regardless of the sheet size.
