Right click -> edit tool in tree opens broken tool manager window
Mattxer
Mattxer
When trying to edit a tool from the tree the window opens and looks like this.
Matt Smith
Software Engineer - MSmithDev - https://msmithdev.com/
CAD/CAM/CNC - Micro Insert Inc. - https://microinsertinc.com/
jhackney1972
I do not see the same problem when I replicate your process.  I am running DirectX 11.0 instead of the latest 12.0.  Maybe you could give that a try and see if it helps.  Remember you must restart the operating system after switching.
John Hackney, Retired
Mattxer
It's actually an issue with the new tool library all together. Someone else has also posted with the same issue https://forums.autodesk.com/t5/fusion-360-manufacture/new-tool-library/m-p/9459161#M79525
Matt Smith
