							Reproducible hang in Sweep on macOS
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Not looking for support, just reporting the bug...
Open the attached file and activate the Shield component. Create -> Sweep and select these three profiles:
Set the mode to Path + Guide Surface. Select the uppermost, outermost rim of the litter box as the path and the uppermost flat face of the litter box as the guide surface:
You'll have to set the extents to something other than 1 and 0; otherwise, the sweep will just fail. (This seems odd to me, but it might be legitimate given the geometry; not sure.)
When you click OK, Fusion 360 should go into permanent "beach ball" mode.
