Reordering components in the browser
markD2LV3
Message 1 of 38
markD2LV3
Is there a way to reorder components in the browser?
I don't mean the history, just simply the top to bottom order of components in the browser, for an arrangement that would be logical to the current design and easy to follow visually.
I'd like to be able to drag them up or down to their "proper" place in the browser, if possible.
Thanks.
Replies (37)
Message 2 of 38
sanket223.patil
Hello @markD2LV3
 I just tried out .  Yes you can change the order of bodies . But not of components , I can't Tell why not components .
Sanket Patil
Mechanical Engineering
Expert Elite
Message 3 of 38
markD2LV3
Thanks.
Message 4 of 38
TrippyLighting
The components appear in the bowser in the order they wer created and that matches with her appearance in teh timeline. It is currently not possible to change the order.
However, if you have a number of components that you feel you want to locate Ito a subassembly (component group) you can create a new, empty component and move existing components into that new component, which then forms an assembly (the icon changes). That can only be done when you are at the end of the timeline.
Message 5 of 38
markD2LV3
A great tip, thank you very much, Peter.
Message 6 of 38
fransK4AG9
I found, that you can re-arrange the icons in the design history timeline.
So if you find the icons for the creation of your components, you can rearrange them on the timeline, and the order in the browser will update. You get the earliest timeline event on top of the browser list ~;~
Message 7 of 38
markD2LV3
I think it works up to a point. I tried it quickly in a fairly simple file and it did not work. But the jury is still out. Thank you for your message.
Message 8 of 38
mika.takalo
Two years from this question. Is there any improvements came yet to this one? Solution is not really good solution.
Message 9 of 38
Cave_Master
Bump.  Will there be a way to drag and re-organize the browser/component tree?
Message 10 of 38
mika.takalo
At least linked items should be possible to organize how ever we want. That should not be problem to implement, because those parts/sub-assemblies wont have any parent data in the current timeline.
Message 11 of 38
mika.takalo
I usually add fasteners(linked parts) as last on to my assembly, so it would be nice if those can be organized and maybe also put in the one "FOLDER" to keep assembly browser even a little bit more shorter.
Message 12 of 38
g-andresen
@mika.takalo wrote:
...so it would be nice if those can be organized and maybe also put in the one "FOLDER"
You can already do this by creating empty folders (primary or in an assembly) and moving the screws ... into them
günther
Message 13 of 38
mika.takalo
How? I know how to make sub-assemblies, but I do not know how to create folders.
Message 14 of 38
g-andresen
oh sorry, I meant "component".
günther
Message 15 of 38
mika.takalo
It will mess up my BOM, making a component from set of fasteners is not a good idea.
Message 16 of 38
g-andresen
have you already looked at the new options for BOM?
günther
Message 17 of 38
mika.takalo
Yes, bom is no longer fit on the screen when changing that one...because I have multiple sub-assys in my main assy.
Message 18 of 38
MaxHugen
I'm still a novice, but as I'm just getting to grips with "best practice", I would find a way to re-order components very helpful as well.
Message 19 of 38
William_Dec_45
I found a work-around: Instead of batch converting to components, convert them one at a time in the order you prefer. First time I've ever been able to contribute. 🙂
Message 20 of 38
joeEVLJ4
Doesn't work.  Dragged a selection of components to the new, empty one and nothing happens.  Not even an error message.
The browser needs a lot of improvements.  Start pushing your product managers to think about usability.  Maybe hire a UX designer instead of more engineers?
--Joe Urban
System: CPU: Intel(R) Core(TM) i9-7920X CPU @ 2.90GHz, 2904 Mhz, 12 Core(s), 24 Logical Processor(s).
MB: X299 XPOWER GAMING AC (MS-7A91)
GPU: GeForce GTX 1080
Installed Physical Memory (RAM) 16.0 GB
Total Virtual Memory 32.7 GB
Water cooled
