- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi all,
It's been a while since I used F360. So after updating, crashing, reinstalling, etc. I got it all working again.
So I wanted to start a new project and went ahead with it.
I created a sketch as usual, draw a few circles positioned them and wanted to apply a rectangular pattern to it. To my surprise this is no longer working. Don't know if it is a bug or am I doing it wrong?
I used to do it like that, saved me a lot of time. But now I'm unable to apply a simple rectangular pattern.
Please refer to my screencast.
I have an additional question for DXF import. I regularly use the same patterns. I was wondering if it is possible to define these as a DXF. And import them in newer design. This seemed to work. Unfortunately the DXF info I imported is no longer constrained to each other. Is there a way to overcome that?
For example if I have 3 holes of different sizes in a row, with a fixed distance between each other. Let say I use the first hole to position the two others. When I constrain that first hole, only that hole moves. The others don't.
So I rephrase my question again. Is there a way to make sure everything out of the DXF is constrained to each other so it is easy to constrain the whole imported drawing?
