Read Only File: Changes are not savable / Renew
brandonstasny16
Observer Observer
brandonstasny16
Observer
Observer
Recently Fusion 360 is not letting me export or save designs. Sketches now show "Read Only File: Changes are not savable / Renew" in the center of the screen. Unsure if its related but I noticed this after a while of not using the software and performing an update. I can open old files however I'm unable to save or export them as well. My personal license is active.
Any help is appreciated!
Brandon
jhackney1972
Please attach some relevant screen captures that show what you are doing and what you see.
John Hackney, Retired
brandonstasny16
Observer
Observer
RajkumarIlanchelian
@brandonstasny16 Can you please collect the logs files for us?
  1. Go to add/remove programs- select Fusion - MODIFY
  2. This will launch the service utility
  3. gather system info
  4. Attach the Fuiondiagnosticslogs.zip
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
brandonstasny16
Observer
Observer
Fusion Dianostic Logs attached. Thanks for the help everyone.
e_consulting_ltd
Did anyone ever help you to find a solution to enable you to save your open work without losing it?
Just being instructed to close session and lose your work is not a valid solution or response.
