"Save as" removed from free hobbyist version??
fapBAGTP
Observer Observer
fapBAGTP
Observer
Observer
Was the "Save As" command removed from the free version?  It now says it is only available in the subscription version.
I am certain I have used it many times before.
TheCADWhisperer
What format are you attempting to Save?
How are you attempting the Save (by right clicking on the body node, by right clicking on Sketch node in the browser)?  More information is needed (screenshots).
jhackney1972
As you can see from the screen capture, the Save As command still exists in the Fusion 360 Personal license.  You must have a model open for it to be available.
John Hackney, Retired
HughesTooling
@jhackney1972 Does it make any difference if you already have 10 designs set as editable? Do you need 9 or less editable designs for this to work?
Mark Hughes
Owner, Hughes Tooling
jhackney1972
If you have 10 of 10 editable documents, the Save As command is unavailable.  You have to have 9 or less, in a Fusion 360 Personal License, to save a new file by any method to the cloud.  The screen capture below is with 10 of 10 editable documents indicated.  Export to your local drive is, of course, still available.
