Python API TableCommandInput not displaying correctly
I am having an issue with the TableCommandInput in the Python API not displaying correctly when it has more than one row and a toolbarCommandInput. I have confirmed on the API forum that the code is working correctly for other people.
I am on:
MacOS 10.15.2
Fusion 2.0.7036
#Fusion360API Python script
import adsk.core, adsk.fusion, traceback
_ui  = None
_handlers = []
class MyCommandCreatedHandler(adsk.core.CommandCreatedEventHandler):
    def __init__(self):
        super().__init__()
    def notify(self, args):
        try:
            cmd = adsk.core.Command.cast(args.command)
            inputs = cmd.commandInputs
            onDestroy = MyCommandDestroyHandler()
            cmd.destroy.add(onDestroy)
            _handlers.append(onDestroy)
            table = inputs.addTableCommandInput('table', '', 4, "")
            for i in range(4):
                for j in range(4):
                    ci = table.commandInputs.addTextBoxCommandInput("tb{}{}".format(i, j), "", "{} . {}".format(i, j), 1, True)
                    table.addCommandInput(ci, i, j)
            button = table.commandInputs.addBoolValueInput('button', 'Button', False, '', True)
            table.addToolbarCommandInput(button)
        except:
            _ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
class MyCommandDestroyHandler(adsk.core.CommandEventHandler):
    def __init__(self):
        super().__init__()
        try:
            adsk.terminate()
        except:
def run(context):
    try:
        app = adsk.core.Application.get()
        global _ui
        _ui = app.userInterface
        cmdDef = _ui.commandDefinitions.itemById('table_test')
        if cmdDef:
            cmdDef.deleteMe()
        cmdDef = _ui.commandDefinitions.addButtonDefinition('table_test', 'table_test', 'table_test')
        onCommandCreated = MyCommandCreatedHandler()
        cmdDef.commandCreated.add(onCommandCreated)
        _handlers.append(onCommandCreated)
        cmdDef.execute()
        adsk.autoTerminate(False)
    except:
        if _ui:
JeromeBriot
No need to duplicate your discussion. The first one is in the good forum (i.e. API forum).
Be patient. Someone at Autodesk will surely add this to the bug tracking system.
People here are less concerned by coding issues.
Ok I am sorry. When looking for the place to report bugs, this forum was suggested. Since it seems to be a bug and not a question about using the API I thought putting it here would be right.
