project drawing dimension issues
evcomaine
evcomaine
I am trying to create workflow drawings based on component part groupings for a traditional (non CNC) woodworking shop. The video will speak more eloquently than I will on this.
jhackney1972
Please attach your MODEL to a reply post.  Open in Fusion 360. Chose the File menu, then Export and save to your hard drive.  You can use the Attachment Section of a reply post.
John Hackney, Retired
jhackney1972
Fractional dimensions in the Drawing are set using the Document Settings, located at the top of the Drawing Browser, not in the Preferences. Please attach your file for explaniation of other issues.
jhackney1972
You have not attached your model?  Did I solve your issue?  If so, please select the "Accept Solution" icon to do three things. First it allows others to find a solution to a similar question, two, it closes the Forum post and last, it acknowledges that you accept the solution given. If you need further help, please ask. If you like to read why "Accept Solutions are important, take a look at this webpage.
