program is slooooow
program is slooooow
gdcm1964
Message 1 of 18
program is slooooow
gdcm1964
extruding a section takes a long time. It's been like that for the last week or so
Replies (17)
Message 2 of 18
TheCADWhisperer
@gdcm1964
Can you attach a file here that exhibits this behavior?
Are you running a 3DConnexion device? If yes try Calibrate.
Message 3 of 18
gdcm1964
It's slow to open now too.I'm getting the "program not responding message now as well.
Rebooted it and seems better. The model I'm working on has a lot of detail.
would that slow down the extrusion?
Message 4 of 18
gdcm1964
I shut it down. It's pretty much useless now. It took well over 15 minutes for the last extrude.
Message 5 of 18
gdcm1964
It's working better this morning. Is it possible that the sheer number of users online was causing it?
Message 6 of 18
gdcm1964
20260926_131530[1].jpgspoke to soon. It's still slooooooow.
This is what I'm working on..
Message 7 of 18
TimelesslyTiredYouth
Could you attach the F3D file, and can we get some specs of the PC? that your using to run Fusion
Ricky
Message 8 of 18
gdcm1964
here you go. 🙂
Message 9 of 18
Can you record an instance of the issue occurring on your phone and upload it to the forum if this is a repeating issue please.
Your specs seem fine for Fusion
Message 10 of 18
gdcm1964
this is what I'm getting now..
Message 11 of 18
(view in My Videos)
So I took a look at your file and timeline in general, I saw a lot of yellow issues within sketches and extrusions, so I can only assume that you misused the delete feature which removed necessary reference data. This is just a wild guess but I'm presuming it is most likely because of Fusion 360 having to work on cache data only without the original data which is potentially causing your PC to slow down.
Regarding the sketch I zoomed in on in the photo, Are you tracing an image and just extruding it upwards to create the design of this badge your making? as there may be a more efficient way to achieve your desired end result with either an application for fusion 360 called Salvador project or just another method that could drastically reduce your timeline,
Could you show your reference photo and explain your end goal please?
Ricky
Message 12 of 18
 It's a bit rushed but is this the rough layout of what you're trying to achieve? from the name I'm guessing it's a badge, there should be enough room towards the centre "leaf"? Canadian leaf? to fit a pin in.
Ricky
Message 13 of 18
gdcm1964
Hi Ricky.
I'm making a trailer hitch insert for a friend that served in the Airborne Regiment.
I'm going to print it in multiple colours which is why I have the different layers.
I dug around the internet and found another picture of the hat badge that doesn't see to be as detailed.
I'm going to try extruding that one.
Message 14 of 18
gdcm1964
This is the picture I'm working with now
Message 15 of 18
using Project Salvador may help you with the process:
 Rather than having the many sketches you had originally.
Message 16 of 18
gdcm1964
so I downloaded Project Salvador, installed it and I can't find it anywhere. lol
Message 17 of 18
Just to check, after downloading Project Salvador, you ran the application so Fusion can detect it? as in attempt to open the Project Salvador file you downloaded.
If so, then just follow the video below and you can apply Project Salvador:
*ignore the fact that I somehow enabled another application alongside Salvador
(view in My Videos)
Hope it helps,
Ricky
Message 18 of 18
gdcm1964
Tks. It was installed..I just couldn't find the link to it.
Time for a coffee and more frustration. lol
