Problems with Loft, Properties of Bodies and Scallop
karlheinzstoeber
Message 1 of 8
karlheinzstoeber
Dear Fusions,
I would like to report a few problems with Fusion and hope that they can be fixed in a timely manner:
Loft creates full body even though only profiles are selected
This problem existed already a year or two ago. With yesterday's update, it's back. Although two profiles are selected, a full body is created. The problem can be bypassed by first creating the body and then cutting it. However, the behavior is cumbersome and does not correspond to the described functioning.
Bildschirmfoto 2021-01-21 um 09.20.49.pngBildschirmfoto 2021-01-21 um 09.20.49.png
Body properties display incorrect values for the Bounding Box
The width of the body shown in the following picture is 4 mm. However, the dialog shows  9.75 mm. For other similar bodies in this project, also 4 mm wide, different width values are also displayed.
Bildschirmfoto 2021-01-21 um 09.22.40.pngBildschirmfoto 2021-01-21 um 09.22.40.png
Scallop ignores Bottom Height when Machine Areas Using Boundaries is turned on
According to Manual, Bottom Height is a limit value that must not be lowered. If the Machine Areas Using Boundaries option is turned on, this is not the case. The undershooting of the limit value can also be seen in the G-code.
Machine Areas Using Boundaries turned offMachine Areas Using Boundaries turned off
Machine Areas Using Boundaries turned onMachine Areas Using Boundaries turned on
Replies (7)
Message 2 of 8
g-andresen
Creating a solid loft with a ring , for example, has never been possible before.
You always had to take the detour via cutting.
günther
Message 3 of 8
karlheinzstoeber
Dear Günter,
thank you for your reply. I don't know if I understood you right. I've selected two rings and the loft created is a solid. To create the body I want, additional cutting is nessesary. I'm absolutly sure that the behavior has changed over time, because I need such bodies very often.
Regards Karlheinz
Message 4 of 8
g-andresen
Hi Karlheinz,
Until now, it was definitely the case that 2 loft processes were necessary for such "rings".
1. loft 1 > total body
2. loft 2 > inner body > "cut" option
Günther
Message 5 of 8
karlheinzstoeber
Dear Günther,
maybe you are right. But if this is the case, this behavior is limited to rings or other closed forms. See following open form where loft works as expected.
Best regards
KarlheinzBildschirmfoto 2021-01-21 um 12.57.21.pngBildschirmfoto 2021-01-21 um 12.57.21.png
Message 6 of 8
TrippyLighting
... this behavior is limited to rings or other closed forms.
Correct! Has always been the case!
The bounding box behavior has been reported a number of times but I am not sure it's been recognized as a bug. @jeff_strater could you look at this?
Message 7 of 8
jeff_strater
correct on all fronts.  The behavior with closed profiles has always been there, and is likely to continue to exist for a while.  We'd like to fix it some day, but because there is a workaround, TBH, it is pretty far down on the list.
Regarding the bounding box, the properties here don't guarantee the tightest bounding box possible.  It's really meant to be an approximation, just to give you a sense of generally how big the component is.
Jeff Strater
Engineering Director
Message 8 of 8
karlheinzstoeber
Thank you all.
@JeffStrater: I think you're joking. The difference between the true value and the one shown in my example is more than 200%.
The Manufacture Workspace (Setup->Stock->Relative Size Box) shows that the values of the Bounding Box can also be determined very precisely.  Maybe the design team should talk to the manufacture team. A good solution is already implemented in Fusion.
