Sketch not defined & I can't figure out why?
Hi All, second post in as many days!
I've cut some slots in a bar & 30°. It took me a little while to figure out how to do this but I used two construction planes to sketch on at the correct distances.
My issue is the sketch is not constrained and I've tried every which way to work out why. I normally get errors saying over-constrained or cannot solve. Please help, I'm sure there was probably a better way to achieve the slots so i am all ears.
Thanks, Paul
seth.madore
It looks constrained to me.....
Seth Madore
Hi @seth.madore,
This is what I thought. When I go to assemble with the mating components the slots are missing.
Are you able to suggest another way of sketching the features?
Thanks, Paul
seth.madore
There aren't any mating components in the file you shared. Did you "insert linked component" into another design? Can you share the proper files here?
Seth Madore
g-andresen
The cause is the undefined construction line for angular dimensioning (150°) .
But this has no influence on the other problem.
günther
@seth.madorenot to worry all sorted now!
Thanks @g-andresen much appreciated!
